WizNet 550io and OLED webserver.txt (7.83 KB)Hi
I am having strange problems with the WizNet 550io module and a Arduino Micro.
I installed the latest WizNet library, replacing the default.
For example. I am trying to get the Ethernet Webserver example to work.
Serial reports IP address as 0.0.0.0, but the default is pingable but No web response.
I have also modified the example and using a Display, I monitor the localIP and it appears to jump around randomly!
I have taken this same code (only editing the utility file) and compiled it for a Arduino Uno with the Ethernet Shield ( I think its a WizNet 5200…) and it worked perfectly.
I have aversion 1.0 WizNet Module and tried different Arduino Micros.
The OLDE display is a 96x128 from Adafruit, using different pins and not SS, MOSI, MISO or SCLK - as for the WizNet.
I have attached the code:
Any advice greatly appreciated.
