Hello!
I am using Wiz550io V1.3 together with STM32F401 DISCOVERY. I use CubeMX32 and IAR EW for ARM. I want to ping the module, but I don’t get a response from it. My code:
/* USER CODE BEGIN Includes /
#include “stm32f4xx_hal.h”
#include “wizchip_conf.h”
#include “socket.h”
#include “loopback.h”
#define HTTP_SOCKET 1
#define SOCK_TCPS 0
#define PORT_TCPS 5000
#define DATA_BUF_SIZE 2048
uint8_t gDATABUF[DATA_BUF_SIZE];
uint8_t buf[2] = {0x00, 0x00};
uint8_t buf_mac[6] = {0,0,0,0,0,0};
uint8_t pbuf_mac = &buf_mac[0];
uint8_t buf_ip[4] = {0,0,0,0};
uint8_t* pbuf_ip = &buf_ip[0];
uint8_t buf_mask[4] = {0,0,0,0};
uint8_t* pbuf_mask = &buf_mask[0];
uint8_t buf_gate[4] = {0,0,0,0};
uint8_t* pbuf_gate = &buf_gate[0];
uint8_t buf_dns[4] = {0,0,0,0};
uint8_t* pbuf_dns = &buf_dns[0];
uint8_t myip[7] = {0x00, 0x0F, 0x04, 0xC0, 0xA8, 0x2D, 0x0C};
uint8_t mymac[9] = {0x00, 0x09, 0x00, 0x00, 0x08, 0xDC, 0x5F, 0x39, 0x4C};
/* USER CODE END Includes */
/* Private function prototypes ----------------------------------------------- /
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_SPI1_Init(void);
static void MX_TIM1_Init(void);
static void MX_USART6_UART_Init(void);
/ USER CODE BEGIN PFP /
void usDelay(uint32_t time); // timer
void W5500_Select(); // Chip select
void W5500_Unselect(); // Chip unselect
void W5500_ReadBuff(uint8_t buff, uint16_t len);
void W5500_WriteBuff(uint8_t* buff, uint16_t len);
void W5500_WriteByte(uint8_t byte);
void sendinfo ();
void sendinfo1 ();
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
uint8_t W5500_ReadByte(void)
uint8_t byte;
W5500_ReadBuff(&byte, sizeof(byte));
return byte;
wiz_NetInfo gWIZNETINFO = { .mac = {0x00, 0x08, 0xdc, 0x5f, 0x39, 0x4a},
.ip = {192, 168, 22, 3},
.sn = {255, 255, 255, 0},
.gw = {192, 168, 88, 1},
.dns = {0, 0, 0, 0},
.dhcp = NETINFO_STATIC };
/* USER CODE END 0 */
int main(void)
/* Initialize all configured peripherals /
MX_GPIO_Init();
MX_SPI1_Init();
MX_TIM1_Init();
MX_USART6_UART_Init();
/ USER CODE BEGIN 2 */
HAL_GPIO_WritePin(GPIOC, GPIO_PIN_5, GPIO_PIN_RESET); // Pin nRESET down
usDelay(501);
HAL_GPIO_WritePin(GPIOC, GPIO_PIN_5, GPIO_PIN_SET); // Pin nRESET up
usDelay(1010);
uint8_t rx_buff_sizes[8] = {2, 2, 2, 2, 2, 2, 2, 2};
uint8_t tx_buff_sizes[8] = {2, 2, 2, 2, 2, 2, 2, 2};
wizchip_init(tx_buff_sizes, rx_buff_sizes);
reg_wizchip_cs_cbfunc(W5500_Select, W5500_Unselect);
reg_wizchip_spi_cbfunc(W5500_ReadByte, W5500_WriteByte);
reg_wizchip_spiburst_cbfunc(W5500_ReadBuff, W5500_WriteBuff);
wizchip_setnetinfo(&gWIZNETINFO);
sendinfo(); // send to PC by UART all gWIZNETINFO
wizchip_getnetinfo(&gWIZNETINFO);
usDelay(1000);
sendinfo();
void W5500_Select(void)
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_RESET);
void W5500_Unselect(void)
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_SET);
void W5500_ReadBuff(uint8_t* buff, uint16_t len)
HAL_SPI_Receive(&hspi1, buff, len, 0xFFFFFFFF);
HAL_SPI_Transmit(&hspi1, buff, len, 0xFFFFFFFF);
W5500_WriteBuff(&byte, sizeof(byte));
I watched the signal using an oscilloscope and see how packets go via SPI to the module by the command win chip_set net info and the module responds by the command wizchip_getnetinfo. I made a sendinfo(); function that sends gWIZNETINFO over UART to COM port PC and I see this:
00 00 00 00 00 00 - mac
00 00 00 00 - ip
3F FF FF FC - mask
00 00 00 00 - gate
00 00 00 00 - dns
And these values may vary depending on the day of the week))) (I can’t understand the dependencies of changing this data).
Please tell me, maybe I’m missing something?
