I’ve been evaluating the WizFi360-EVB-Pico board but getting very bogged down. Neither of the example project WizFi360-EVB-Pico-C or WizFi360-EVB-Pico-AWS-C compile for me. Both show missing files, such as freertos_evr.h.
I have managed to build an example that connects to an AP and then initiates a socket. Even just bring back 100 bytes of data causes cmsis_os2.c block allocation to attempt a null pointer assignment. Does any one have any example code that works for this board?
It is a shame the WizFi360 module does not support the AT+CIPSTARTEX command, as it looks like that would allow the lwesp library to work with the board. That would be a great deal easier than the CMSIS ecosystem that seems to be problematic.
Thanks. I use Eclipse on Mac and build on RPI 4 Ubuntu 20.04.
Can I suggest a tutorial or documentation explaining versions and the build process to get it to succeed? Certainly, I found it a lot of work to get a working version.
Because it supports the development environment using Visual Studio Code on Windows, it is difficult to support the development environment using Eclipse on MAC and R-PI 4 Ubuntu.
