Just got a WizFi360-EVP-Pico board. Installed uf2 for Micropython and can blink led etc. and it shows on wifi as an access point.
However, other posts indicate there is no micropython support for setting up a web server. Is this still correct???
Hello @John_Lucas
Currently, the WizFi360-EVB-Pico Micropython example does not support the web server example.
Therefore, in order to set up and use the web server, you need to implement it.
