HI
I see sample code for C but there is no sample code for Micro Python. I tried using the Pico W example but it does not work as the firmware is from Pico H. Is there a way to use Micropython instead of C as I have hard time building the samples.
HI
Hello @Shoban_Kumar
Do you use the WizFi360-EVB-Pico?
Currently, Azure IoT example support C but not MicroPyython.
Therefore, if you need the Azure IoT example implemented with MicroPython, you need to implement it yourself.
