greetings.
Would you have technical information and pdf of the “D1” series?
I see the brochures and something general.
2 TCP ports
Thank you so much
greetings.
2 TCP ports
Thank you so much
Hi, I’m Ron from WIZnet HK.
Please find the attachment for the latest user manual for our W7500S2E-D1.
W7500S2E User Manual V1.3.pdf (3.1 MB)
Please find the following link for a simple demo on how to use W7500S2E-D1.
Ron
The problem in the PDF manual is that there is no clear explanation of the use of 2 ethernet ports. I also do not understand when configuring the explanation for this W7500S2E-D1 module.
The video shows something fast which doesn’t make it clear to me if it’s some kind of switch.
Would you have something more complete in technical pdf?
Can you handle 2 ethernet independently?
only 1 RS232 port?
No more pins available?
technical plans of the plate?
for sale ?
thank you
