I developed a board to use W7500P S2E chip which is preinstalled S2E feature.
But it isn’t connected to network.
When I debug the w7500 S2E F/W in Keil IDE, it shows Link never been successful.
After phy_ini(), the link() doesn’t return return success.
I am using W7500 with PHY IC in different board at the same network, it works fine.
How to check PHY link is up and running correctly.
I have erased the chip whole and programmed it by ULINK2 in Keil.
I have 4 boards which uses the W7500P S2E preprogrammed.
But none of them has been successful in link.
How to check the W7500P internal PHY is up and running ?
How to resolve this situation ?
Thanks for your comment.
I found out I missed the connection ISET to GND through 4K7.
I will try put it on and get the result soon.
Thanks again for your comment.
