Hello all
I need to use
AT+FDNS=someserver.com,1000
- this command act as DNS client
Everything is OK when I connect to my network via command
AT+WNET=1 (AT command for setting DHCP client)
and after successfull joining the wifi I can use AT+FDNS as described
But when I connect to network via static IP address as following example
AT+WNET=0,192.168.2.101,255.255.255.0,192.168.2.1 (AT command for setting
Static IP address)
and join to the wifi network, everytime I use AT+FDNS command I receive ERROR.
I suppose the device miss IP address of DNS server and I don’t know how to set it. The device knows only IP, mask and gateway but miss DNS server IP address
Is there any workaround for this?
