We are currently using a WIZ105SR in a product and have a requirement to allow the user to set a static IP address for the product via an built-in web page. We have the local expertise to write the web page but do not have the knowledge of how to go about loading the address into the WIZ105SR. So I guess the question here is, where are these addresses in the board and what do we need to know in order to access them?
Dear Mwood123
Please read User Manual fully.
old.wiznet.co.kr/sub_modules/en/ … F_KeyWord=
You can verify IP address by configuration tool.
And I think you must use “Serial Commands” to implement HTTP Server.
You can receive or send HTTP packet by using “Serial Commands”.
<P.S.>
I recommend WIZ550web solution.
WIZ550web FW is flexable and open platform.
old.wiznet.co.kr/sub_modules/en/ … d=1243#tab
Dear all,
could you kindly fix the download page for the “WIZ100/105/110SR S2E Programming Guide” because this can’t download the pdf and relink to a web page.
Also is this guide still valid or has it been exceeded by the WIZ100SR User Manual ?
Thank!
Livewire
