We are currently trialing the WIZ120SR module on a board utilising both serial ports.
We have the following problem with our module - can you please shed some light on the issue. Looks to be a memory problem and defaults are being loaded.
Turn on power
Search for device using application
Device found with MAC 39:39:39:39:39:39
Click on device and the following info shows
IP: 192.168.11.100
Subnet: 255.255.255.0
Gateway: 192.168.11.1
Default serial info also shows (serial debugging disabled)
I change any setting and click “Setting”
Settings upload sucessfully
Search for device again and device not found. Cannot contact with serial ports or application until reset of device but it resets to those default settings.
