I am using the terminal program and want to send hex data to the unit. By default everything is sent in ASCII mode. How do I send data in hex format?
Hello.
Simply, Just use the terminal program that supports sending hex data.
Our Serial-to-Ethernet modules doesn’t care of data type(ASCII or HEX).
Thank You. It works like a charm!
