First time i am using W5300 Ethernet in my project. I am not that much strong in Coding part. No other go, i need to run my experiment through W5300. I have connected W5300 to Altera Cyclone V FPGA board. I want to make communication between Board and PC through W5300.
I have created simple Counter design in Altera quartus workspace. I need to run the counter data in Hercules through W5300 (Either TCP or UDP). I don`t know how to create packets [W5300 coding part]. Can anyone guide or can anyone share me the simple example design.
Thanks for your response.
In your attachement, i am able to see only Codes. So Any example design using WIZNET 5300 For Alter Quartus will help me most.
How to interlink Tristate conduit bridge/Generic Controller with WIZNET 5300.
Currently, i am reading the counter data in NIOS using FIFO (SOPC). Now i need to read the data in PC through WIZNET 5300. Please anyone guide me
Hi~ I think you want to use PC and W5300 through network , Is it right?
If is right, you should be select the network protocol(UDP or TCP).
Please refer to previous code about how to use of this protocol(loopback.c)
thanks,
