I ordered 110SR month ago, and I have trouble to configure it correctly, I am newbie with such devices.
- I have device with serial port - Satel Integra, and I want to access that device remotely via PC, the device (Satel) could be accessed only through COM port, (as the Satel communication software uses only COM ports). I want to use the 110SR as the ethernet bridge between PC and Satel like following:
PC with Satel communication software -use COM1 ----- ETHERNET ---- COM port on Satel integra device
I setup the 110SR with ip address 192.168.1.5, setup is as SERVER (I want to access the 110SR from computer), see attached picture01.jpg and on the computer where I want to use the Satel communication software for Satel Integra I installed and configured the VIZ VSP software, see attached picture02.jpg , as you can see I created virtual COM1 port.
Then I run my Satel communication software connected it to COM1, but nothing happened, I cannot connect to the device (192.168.1.5 is pingable and responds to ping). I can see that some data are send to COM1 (part “sent” in picture02.jpg, but from the device there are not sent any data (received=0)) Could someone help me what I am doing wrong with my setup ?
