Hello!
I want to use the two wizfi210s cennect the MTU1and MTU2, meanwhile one of wizfi210 connect the PC.I set the AD-hoc mode,but the PC as the serve can connect the wizfi210 can’t recive data.
How can set the multi-connect with wizfi210?
Hi
I have some question about your environment.
What device is set to TCP server? Is WizFi210 set to TCP server? or PC?
If you want to TCP server for multi-connect in WizFi210, you have to use of WizFi210’s Mode as below.
[quote]
For example
AT+WD
[OK]
AT+WM=1
[OK]
AT+NDHCP=1
[OK]
AT+NSET=192.168.3.50,255.255.255.0,192.168.3.1
[OK]
AT+WA=TEST_AD_HOC
IP SubNet Gateway
192.168.3.50: 255.255.255.0: 192.168.3.1
[OK]
AT+NSTCP=5001
[OK][/quote]
Caution
- In Ad-hoc mode of WizFi210, WizFi210 can’t run DHCP server. So end-device for connecting WizFi210 is set to static IP.
[quote=“kaizen”]Hi
[quote]
For example
AT+WD
[OK]
AT+WM=1
[OK]
AT+NDHCP=1
[OK]
[OK]
AT+WA=TEST_AD_HOC
IP SubNet Gateway
[OK]
AT+NSTCP=5001
[OK][/quote]
Caution
- In Ad-hoc mode of WizFi210, WizFi210 can’t run DHCP server. So end-device for connecting WizFi210 is set to static IP.[/quote]
Thank you for your reply!
My environment like this,I have two systems.Every system has been made up of MTU and Wizfi210. I want to raelize purpose that one MTU_1 send date to Wizfi210_1 by serial port or SPI(complete),as the same time Wizfi210_1 send data to Wizfi210_2 with AD-hoc(complete),at last the Wizfi210_2 send data to MTU2(complete)and PC(not complete).
The status that when PC communicate to Wizfi210_2 ,the Wizfi210_1 don’t communicate Wizfi210_2, only one client(PC or Wizfi210_1) visit the Wizfi210_2(serve).
If I set the Wizfi210_2 to client, meanwhile set at+nctcp.Wizfi210_1 can connect to Wizfi210_2 ,and Wizfi210_2 also connect to PC(serve),but the PC don’t receive data only connect.
If I set the Wizfi210_2 to serve,Wizfi210_1 and PC only one can connect it.
If I set the Wizfi210_2 to serve like this at+nstcp/at+nstcp,PC can connect,Wizfi210_1 can’t.
Do you have some methods to solve problem?
Thank you!
Hi
Refer to this thread.
