Just saw your product on the digikey site. I would like to confirm if it will meet our needs.
Currently we use a PC/linux base TCP client program to communicate (send/receive data) with a wifi module. The module is connected to one of the processor UART ports.
I have used the Digi xbee wifi SB6 module (in transparent mode) as well as the Silicon Labs AMW006-a1u and AMW006-a1w in TCP server mode and both work. I have used both because of their through-hole footprint.
The communication does not use any ‘AT’ commands, just sending/receiving hex bytes.
Can i use the wizfi360io-h similarly, and do you have examples of how to set up the module.
Hi
WizFi360io-h also provide transparent mode. so you can send/receive the messages without the AT commands .
but you should use the AT commands to make a TCP Server mode.
the module supports auto-connection mode, but it only works on the TCP Client mode.
Thanks, i will go ahead and place an order to evaluate.
Does this module have a u.fl connector option for an external antenna (or you have another module with this option).
Hi. Same is the situation and in TCP client mode. Currently I am using WIZ750sr-100 and it is working in transparent mode in both TCP client/server . Are you going to support TCP server transparent mode?
Hi.
We support transparent mode on TCP client mode instead of TCP Server mode.
Because TCP server mode have to manage multiple connection in our structure of the module.(mandantory AT+CIPMUX=1)
as you know, transparent mode is not available in the multi connection state.
I guess AT+CIPMODE command has a bug.
It will be fix. before that you can use transparent mode in TCP client mode with AT+SAVETRANSLINK command.
for example.
OK. I understsand. Now have success. After AT+SAVETRANSLINK , RESTART and switching ON is very unconfortable to send AT command in order to start working in transparent mode. I would like to suggest you to skip this step in future firmwares. Thanks for the support.
Hello
I am using the WIZFI360-EVB-mini board version :
11:14:29.065> AT+GMR
11:14:29.111> AT version:1.0.2.5(Aug 23 2019 17:03:59)
11:14:29.111> SDK version:3.2.0(a0ffff9f)
11:14:29.111> compile time:Aug 23 2019 17:03:59
I have a question regarging the autoconnect as a TCP client to a TCP server
my settings
AT+CWMODE_DEF=1
AT+CIPMUX=0
AT+CWDHCP_DEF=1,1
AT+CWJAP_DEF=“WIFISSID”,“password”
AT+SAVETRANSLINK=1,“192.168.148”,3347,“TCP”
AT+CWAUTOCONN=1
all commands respond with OK
After power on :
14:19:59.702>
14:19:59.702> ready
14:20:01.766> WIFI CONNECTED
14:20:01.951> WIFI GOT IP
14:20:01.951>
14:20:01.951> OK
never connects to the TCP server automatically
Stays in AT mode
If I do understand correct from the datasheet the module should start, connect to wifi and TCP client automatic and proceed to transparent mode without sending any command.
I am using the WIZFI360-EVB-mini board, I have done a setup on by connecting the 2 modules one as client and the other as server,
I guess below command is at the client side
Problem1: can I know from where can we find remote IP address and remote port number of the client?
Problem 2: at the server side I couldn’t find the message when client/station got connected, if I connect with my PC or mobile I will get a message as station connected with MAC and IP address.
Problem 3: Can I make my PC as server and wizfi360-evb-mini as client, but I am unable to find my PC’s SSID by displaying the list of available APs, but I could have connect with my phone by turning on hotspot, what to change in my PC to advertise it’s SSID. is this possible?
