Hi we have several units using a WIZ145SR that became unresponsive after a few hours of use. This is not a common failure but have seen it before. We could ping the unit, but could not open any ports for serial to ethernet and could not find it using the WIZ14xSR tool. Power cycling fixed the problem.
Any suggestions for troubleshooting if this happens again? Is there any kind of error report logging or SNMP monitoring that can be done?
Thanks,
Casey
