WIZVSP cann't run again
First time I used WIZVSP to create virtual serial port successful. When I run the WIZVSP again, I can’t to create another virtual serial port for my second WIZ110SR board. The error message is “cannot add the defined connection”. How can I to solver this problem.
Hi.
First, I successful. another creation com port.
So, are you using what tool version?
I using WIZ VSP 1.7.0.
Please check to your version.
And, refer to below lint (WIZ VSP Userguide)
youtube.com/watch?v=r6tnqgtAHfc
Thank you
The solution is to upgrade to a newer version.
