void main(void)
// send data
//Uint16 rdata; // received data
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
InitSysCtrl();
// Step 2. Initialize GPIO:
InitSpiaGpio();
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
DINT;
// Initialize PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2833x_PieCtrl.c file.
InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
IER = 0x0000;
IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// The shell ISR routines are found in DSP2833x_DefaultIsr.c.
// This function is found in DSP2833x_PieVect.c.
InitPieVectTable();
// Step 4. Initialize all the Device Peripherals:
// This function is found in DSP2833x_InitPeripherals.c
spi_fifo_init(); // Initialize the Spi FIFO
spi_init(); // init SPI
// Step 5. User specific code:
// Interrupts are not used in this example.
for(;
// Transmit data
GpioDataRegs.GPBCLEAR.bit.GPIO57 = 1;
MR_reg ();
GpioDataRegs.GPBCLEAR.bit.GPIO57 =1; // SCS asserted low for data transmission
GAR();
GpioDataRegs.GPBSET.bit.GPIO57 = 1; // SCS asserted high to inidcate end of the frame.
SUBR();
SHAR();
SIPR();
Sn_MR();
Sn_PORT();
opencmd();
Sn_DIPR();
Sn_DPORT();
listencmd ();
txdata ();
sendcmd ();
// Wait until data is received
//while(SpiaRegs.SPIFFRX.bit.RXFFST !=1) { }
// Check against sent data
//rdata = SpiaRegs.SPIRXBUF;
//if(rdata != sdata) error();
asm (" NOP");
// spi frame data functions:
void MR_reg ()
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x00;
spi_xmit(sdata);
sdata =0x04;
spi_xmit(sdata);
sdata = 0x10;
spi_xmit(sdata);
void GAR()
//ip address mac SUBR SHAR SIPR are set here
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x01;
spi_xmit(sdata);
sdata = 0x04;
spi_xmit(sdata);
sdata = 0xC0;
spi_xmit(sdata);
sdata = 0xA8;
spi_xmit(sdata);
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x01;
spi_xmit(sdata);
void SUBR()
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x05;
spi_xmit(sdata);
sdata = 0x04;
spi_xmit(sdata);
sdata = 0xFF;
spi_xmit(sdata);
sdata = 0xFF;
spi_xmit(sdata);
sdata = 0xFF;
spi_xmit(sdata);
sdata = 0x00;
spi_xmit(sdata);
void SHAR()
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x09;
spi_xmit(sdata);
sdata = 0x04;
spi_xmit(sdata);
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x08;
spi_xmit(sdata);
sdata = 0xDC;
spi_xmit(sdata);
sdata = 0x01;
spi_xmit(sdata);
sdata = 0x02;
spi_xmit(sdata);
sdata = 0x03;
spi_xmit(sdata);
void SIPR ()
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x0F;
spi_xmit(sdata);
sdata = 0x04;
spi_xmit(sdata);
sdata = 0xC0;
spi_xmit(sdata);
sdata = 0xA8;
spi_xmit(sdata);
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x02;
spi_xmit(sdata);
void Sn_MR()
// Sn3_MR reg
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x04;
spi_xmit(sdata);
sdata = 0x01;
spi_xmit(sdata);
void Sn_PORT()
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x04;
spi_xmit(sdata);
sdata = 0x0C;
spi_xmit(sdata);
sdata = 0x13;
spi_xmit(sdata);
sdata= 0x88;
spi_xmit(sdata);
void opencmd()
//Sn_CR reg
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x01;
spi_xmit(sdata);
sdata = 0x0C;
spi_xmit(sdata);
sdata = 0x01;
spi_xmit(sdata);
void Sn_DIPR()
//destination IP address
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x0C;
spi_xmit(sdata);
sdata = 0x0C;
spi_xmit(sdata);
sdata = 0xC0;
spi_xmit(sdata);
sdata = 0xC0;
spi_xmit(sdata);
sdata = 0xA8;
spi_xmit(sdata);
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x0B;
spi_xmit(sdata);
void Sn_DPORT()
//destination port number
sdata = 0x00;
spi_xmit(sdata);
sdata= 0x10;
spi_xmit(sdata);
sdata = 0x0C;
spi_xmit(sdata);
sdata = 0x13;
spi_xmit(sdata);
sdata = 0x88;
spi_xmit(sdata);
void listencmd () // working in tcp server mode changed to TCP client mode listen chnaged to connect
//Sn_CR
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x01;
spi_xmit(sdata);
sdata = 0x0C;
spi_xmit(sdata);
sdata = 0x04;
spi_xmit(sdata);
void txdata ()
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x14;
spi_xmit(sdata);
sdata = 0xAA;
spi_xmit(sdata);
sdata = 0xAA;
spi_xmit(sdata);
void sendcmd()
sdata = 0x00;
spi_xmit(sdata);
sdata = 0x01;
spi_xmit(sdata);
sdata = 0x0C;
spi_xmit(sdata);
sdata = 0x20;
spi_xmit(sdata);
// Step 7. Insert all local Interrupt Service Routines (ISRs) and functions here:
void delay_loop()
long i;
for (i = 0; i < 1000000; i++) {}
void error(void)
__asm(" ESTOP0"); // Test failed!! Stop!
for (;;);
void spi_init()
SpiaRegs.SPICCR.all =0x0007; // Reset on, rising edge, 16-bit char bits
SpiaRegs.SPICTL.all =0x0006; // Enable master mode, normal phase,
// enable talk, and SPI int disabled.
SpiaRegs.SPIBRR =0x007F;
SpiaRegs.SPICCR.all =0x0097; // Relinquish SPI from Reset
SpiaRegs.SPIPRI.bit.FREE = 1; // Set so breakpoints don’t disturb xmission
void spi_xmit(uint8 a)
SpiaRegs.SPITXBUF=a;
void spi_fifo_init()
// Initialize SPI FIFO registers
SpiaRegs.SPIFFTX.all=0xE040;
SpiaRegs.SPIFFRX.all=0x204f;
SpiaRegs.SPIFFCT.all=0x0;
